12 years agofir filter for fsk demodulator
Hi, i've realized an i_q demodulator for fsk message. The frequencies for the 0 and for the 1 are spaced 400Hz; the baud rate is up 200baud. The frequencies are in the audio range (for example F...
12 years ago --- Quote Start --- what is that 20KHz? --- Quote End --- The frequencies for the fsk messagge are in the range 3Khz to 20Khz, so for example a message could be modulated with 4050 for F0 and 4450 for F1 and another message could be modulated with 18000 for F0 and 18400 for F1. --- Quote Start --- baud = 200, can't be --- Quote End --- the data baud rate is up to 200baud (i.e. from 40Hz to 200Hz) --- Quote Start --- IQ demod outputs: IQ demodulator downconverts to what values for f0,f1 you will need to filter the second sideband on each of I and Q after downconversion. So you need to tell us what is f0,f1 after IQ demod and what is sampling rate. --- Quote End --- I think i need 2 iq demodulator one for F0 freq and another for f1 signal,is it right? At the moment the sampling rate is 200khz... The last question is not so clear...
