12 years agoFIR Compiler II multichannel operation
Hi all. I'm using FIR compiler II megafunction to create a block with the following parameters: Decimation filter this N = 2; Number of channels : 11; Clock frequency : 50 MHz; Input...
12 years ago --- Quote Start --- I didn't describe the problem, my fault. I have 11 fir filters connected in series, each with decimation factor = 2, clock frequence = 120 kHz,same coefficients and different input sample rates (because of the decimation): 1. 120 kHz 2. 60 kHz 3. 30 kHz 4. 15 kHz 5. 7500 Hz 6. 3750 Hz 7. 1875 Hz 8. 937,5 Hz 9. 468,75 Hz 10. 234,375 Hz 11. 117,1875 kHz It's working, but can't fit in our FPGA, even in case of increasing clock frequence. Thats why I want to do it with one filter and 11 channels. So, I want to use this channels with different frequences. I hope I explained the problem clear. What do you think about it? --- Quote End --- if your sampling rate is halved each time then you can't use multichannel as it expects one sample rate. You can decimate in a cascade but filters need not be identical as that is a waste of resource. you can reduce the burden on cutoff point as you go down the cascade. Alternatively you can decimate in one filter and that will also reduce resource due to decimation effect internally.
