12 years agoFIR Compiler II multichannel operation
Hi all. I'm using FIR compiler II megafunction to create a block with the following parameters: Decimation filter this N = 2; Number of channels : 11; Clock frequency : 50 MHz; Input...
12 years agoWhen I said dummy samples I mean you just assert valid and it doesn't matter what value goes on the input at that point. It will produce "fake" results, but it doesn't matter as you will only be selecting the results from the channels you care about.
