12 years agoFIR Compiler II multichannel operation
Hi all. I'm using FIR compiler II megafunction to create a block with the following parameters: Decimation filter this N = 2; Number of channels : 11; Clock frequency : 50 MHz; Input...
12 years agoThanks all of you.
So, valid and sop/eop signals: valid high - all 11 cycles sop high - only 1 cycle eop high - only 11 cycle. Is this true? And what about dummy samples? I think that i can't send dummy samples, because this will fake results. It seems that there is no solution of this problem.
