12 years agoFIR Compiler II multichannel operation
Hi all. I'm using FIR compiler II megafunction to create a block with the following parameters: Decimation filter this N = 2; Number of channels : 11; Clock frequency : 50 MHz; Input...
12 years agoyour valid is ok.
your SOP,EOP what are these? I assume some start/end of some frames. If you are filtering then I don't know what frames mean here. Can you explain it please?
