16 years agoFind correct device
Hello I have not a big aknowledge of Altera chips, until now I have worked only whith chip Acex and Max2, can somebody, suggest which chip I can use for insert a core of 8032, and to have a good spac...
16 years agoHi,
that will depend on your 8032 core is and how much ROM and RAM you'll need. I have used the 8052 core from OpenCore's T51 project. The original core took a huge amount of resources, due to the way IRAM and ROM were implemented. With a couple of modifications, I managed to reduce it to some 8K LEs. The design also has some 16KB ROM and 4KB XRAM, all implemented in the FPGAs M9K blocks. This, plus a bunch of peripherals, all fit in a EP2C20. As for tools, you'll need a) a 8051 compiler, libraries, etc. sdcc is pretty decent. b) a 8051 emulator to debug your sofware. c) ModelSim to simulate your complete design. In any case, unless you have a really good reason not to, I suggest you use the NIOS II processor. Compared to the free 8051 cores I've seen: - NIOS II/e is also free. - NIOS II/e takes much less resources. - NIOS II is faster, even /e. - There are much better tools for development and debugging.
