17 years agofinal year project help needed in fir design
1. i m designing an fir filter actually what i m doing is representing the general fir equation in schematic logic using shift register in delay units, the multiplexer uses sel line common to bot...
17 years ago --- Quote Start --- can't i do the analysis and sythesis of the package seperage ly of just saving the file add its up to work .all coz every time i compile the design it send top level entity no defined --- Quote End --- You cannot synthesise a package on its own because it contains no entities. You need a top level entity to synthesise. You might be best sticking the package into modelsim and compiling it there for syntax checking. Also, please use numeric_std instead of std_logic_arith.
