16 years agoFilter & decimation implementation on AD7401
Hello everybody! We have chosen the AD7401 Sigma Delta modulator for our project, translated the Verilog code given by the datasheet into VHDL and are now confused about the results of the simu...
16 years agoOk, we tried to merge in some way the code of ADS1202 and AD7401, and we got really great results of the code which came out.
The first figure is with feeding 0's and then random input, and the second one is with 1s first and then random values. http://i252.photobucket.com/albums/hh3/unoturbomk2/2-3.jpg http://i252.photobucket.com/albums/hh3/unoturbomk2/1-5.jpg As you can see the code responses to the simulation quite well, respecting that it actually takes 2 words/samples for the code to respond to sudden changes of input values, due to the 3rd order sinc filter. The code is attached. If someone could confirm that this is correct, we'd appreciate it! Thank you!
