13 years agoFIFOED UART in QSYS
I am using qsys version 13.0 sp1 for building a design. My target device is Cyclone V. There is a FIFOED_UART module intergarted in my design. When I press generate I see this error: generatin...
12 years agoI'm having the same problem on Ubuntu Linux 14.04 with QSys 13.1 and the FIFOED avalon uart failing to generate. The same project generates/compiles fine on a Windows Quartus II/QSys 13.1 installation on the same computer. Was there a resolution for this?
Error: fifoed_avalon_uart_0: Generation callback did not provide a top level file (expected `add_file $output_dir/soc_system_fifoed_avalon_uart_0.v|vhd|sv {SIMULATION SYNTHESIS}`) Error: fifoed_avalon_uart_0: syntax error at /home/xxx/altera/13.1/quartus/sopc_builder/bin//europa/e_lpm_altsyncram.pm line 203, near ")" (Might be a runaway multi-line () string starting on line 197) syntax error at /home/xxx/altera/13.1/quartus/sopc_builder/bin//europa/e_lpm_altsyncram.pm line 207, near "}" Global symbol "$this" requires explicit package name at /home/xxx/altera/13.1/quartus/sopc_builder/bin//europa/e_lpm_altsyncram.pm line 222. syntax error at /home/xxx/altera/13.1/quartus/sopc_builder/bin//europa/e_lpm_altsyncram.pm line 248, near "}" Compilation failed in require at /home/xxx/altera/13.1/quartus/sopc_builder/bin//europa/europa_all.pm line 203. BEGIN failed--compilation aborted at /home/xxx/altera/13.1/quartus/sopc_builder/bin//europa/europa_all.pm line 203. Compilation failed in require at mk_em_uart_sa.pl line 8. BEGIN failed--compilation aborted at mk_em_uart_sa.pl line 8. while executing "exec perl -I . -I /home/xxx/altera/13.1/quartus/sopc_builder/bin/ -I /home/xxx/altera/13.1/quartus/sopc_builder/bin//europa/ -I /home/xxx/..." ("eval" body line 1) invoked from within "eval $exec_list" (procedure "generate" line 70) invoked from within "generate"
