16 years agoFCS(crc32) ethernet on cycloneII?
I have tested free internet codes for FCS ethernet, but it don't work.
What's wrong? HELP me please gurus! CRC32 FOR 1 FIXED BYTE(0X1A) rstn->always 0 enable->always 1 init->1 time 1 short pulse for init crc module DataIN->0x1A CRC generated from module-> 0x2D93B212 CORRECT CRC->0xf716602f internet code: module crc32_data8 ( clk, rstn, enable, init, d, //datain crc, //crc match //set if crc=0 ); input clk; input rstn; input enable; input init; input [7:0] d; output [31:0] crc; output match;   wire [31:0] c; wire [31:0] newcrc; reg [31:0] crc; reg match;   always @ (posedge clk ) begin if(rstn) begin crc [31:0] <= {32{1'b1}}; match <= 1'b0; end else begin if(init) begin crc [31:0] <= {32{1'b1}}; match <= 1'b0; end else if(enable) begin crc <= newcrc; if (crc==32'd0) match<=1'b1; else match<=1'b0; end end end   assign c = crc; assign newcrc[0] = d[6] ^ d[0] ^ c[30] ^ c[24]; assign newcrc[1] = d[7] ^ d[6] ^ d[1] ^ d[0] ^ c[31] ^ c[30] ^ c[25] ^ c[24]; assign newcrc[2] = d[7] ^ d[6] ^ d[2] ^ d[1] ^ d[0] ^ c[31] ^ c[30] ^ c[26] ^ c[25] ^ c[24]; assign newcrc[3] = d[7] ^ d[3] ^ d[2] ^ d[1] ^ c[31] ^ c[27] ^ c[26] ^ c[25]; assign newcrc[4] = d[6] ^ d[4] ^ d[3] ^ d[2] ^ d[0] ^ c[30] ^ c[28] ^ c[27] ^ c[26] ^ c[24]; assign newcrc[5] = d[7] ^ d[6] ^ d[5] ^ d[4] ^ d[3] ^ d[1] ^ d[0] ^ c[31] ^ c[30] ^ c[29] ^ c[28] ^ c[27] ^ c[25] ^ c[24]; assign newcrc[6] = d[7] ^ d[6] ^ d[5] ^ d[4] ^ d[2] ^ d[1] ^ c[31] ^ c[30] ^ c[29] ^ c[28] ^ c[26] ^ c[25]; assign newcrc[7] = d[7] ^ d[5] ^ d[3] ^ d[2] ^ d[0] ^ c[31] ^ c[29] ^ c[27] ^ c[26] ^ c[24]; assign newcrc[8] = d[4] ^ d[3] ^ d[1] ^ d[0] ^ c[28] ^ c[27] ^ c[25] ^ c[24] ^ c[0]; assign newcrc[9] = d[5] ^ d[4] ^ d[2] ^ d[1] ^ c[29] ^ c[28] ^ c[26] ^ c[25] ^ c[1]; assign newcrc[10] = d[5] ^ d[3] ^ d[2] ^ d[0] ^ c[2] ^ c[29] ^ c[27] ^ c[26] ^ c[24]; assign newcrc[11] = d[4] ^ d[3] ^ d[1] ^ d[0] ^ c[3] ^ c[28] ^ c[27] ^ c[25] ^ c[24]; assign newcrc[12] = d[6] ^ d[5] ^ d[4] ^ d[2] ^ d[1] ^ d[0] ^ c[4] ^ c[30] ^ c[29] ^ c[28] ^ c[26] ^ c[25] ^ c[24]; assign newcrc[13] = d[7] ^ d[6] ^ d[5] ^ d[3] ^ d[2] ^ d[1] ^ c[5] ^ c[31] ^ c[30] ^ c[29] ^ c[27] ^ c[26] ^ c[25]; assign newcrc[14] = d[7] ^ d[6] ^ d[4] ^ d[3] ^ d[2] ^ c[6] ^ c[31] ^ c[30] ^ c[28] ^ c[27] ^ c[26]; assign newcrc[15] = d[7] ^ d[5] ^ d[4] ^ d[3] ^ c[7] ^ c[31] ^ c[29] ^ c[28] ^ c[27]; assign newcrc[16] = d[5] ^ d[4] ^ d[0] ^ c[8] ^ c[29] ^ c[28] ^ c[24]; assign newcrc[17] = d[6] ^ d[5] ^ d[1] ^ c[9] ^ c[30] ^ c[29] ^ c[25]; assign newcrc[18] = d[7] ^ d[6] ^ d[2] ^ c[31] ^ c[30] ^ c[26] ^ c[10]; assign newcrc[19] = d[7] ^ d[3] ^ c[31] ^ c[27] ^ c[11]; assign newcrc[20] = d[4] ^ c[28] ^ c[12]; assign newcrc[21] = d[5] ^ c[29] ^ c[13]; assign newcrc[22] = d[0] ^ c[24] ^ c[14]; assign newcrc[23] = d[6] ^ d[1] ^ d[0] ^ c[30] ^ c[25] ^ c[24] ^ c[15]; assign newcrc[24] = d[7] ^ d[2] ^ d[1] ^ c[31] ^ c[26] ^ c[25] ^ c[16]; assign newcrc[25] = d[3] ^ d[2] ^ c[27] ^ c[26] ^ c[17]; assign newcrc[26] = d[6] ^ d[4] ^ d[3] ^ d[0] ^ c[30] ^ c[28] ^ c[27] ^ c[24] ^ c[18]; assign newcrc[27] = d[7] ^ d[5] ^ d[4] ^ d[1] ^ c[31] ^ c[29] ^ c[28] ^ c[25] ^ c[19]; assign newcrc[28] = d[6] ^ d[5] ^ d[2] ^ c[30] ^ c[29] ^ c[26] ^ c[20]; assign newcrc[29] = d[7] ^ d[6] ^ d[3] ^ c[31] ^ c[30] ^ c[27] ^ c[21]; assign newcrc[30] = d[7] ^ d[4] ^ c[31] ^ c[28] ^ c[22]; assign newcrc[31] = d[5] ^ c[29] ^ c[23]; endmodule2 Replies
the right code (it needs only invert the outputs with the module myblkinv2):
TNX to your help module crc32_data8 ( clk, rstn, enable, init, d, //datain crc, //crc match //set if crc=0 ); input clk; input rstn; input enable; input init; input [7:0] d; output [31:0] crc; output match; wire [31:0] c; wire [31:0] newcrc; reg [31:0] crc; reg match; always @ (posedge clk ) begin if(rstn) begin crc [31:0] <= {32{1'b1}}; match <= 1'b0; end else begin if(init) begin crc [31:0] <= {32{1'b1}}; match <= 1'b0; end else if(enable) begin crc <= newcrc; if (crc==32'd0) match<=1'b1; else match<=1'b0; end end end assign c = crc; assign newcrc[0] = d[7] ^ d[1] ^ c[30] ^ c[24]; assign newcrc[1] = d[7] ^ d[6] ^ d[1] ^ d[0] ^ c[31] ^ c[30] ^ c[25] ^ c[24]; assign newcrc[2] = d[7] ^ d[6] ^ d[5] ^ d[1] ^ d[0] ^ c[31] ^ c[30] ^ c[26] ^ c[25] ^ c[24]; assign newcrc[3] = d[6] ^ d[5] ^ d[4] ^ d[0] ^ c[31] ^ c[27] ^ c[26] ^ c[25]; assign newcrc[4] = d[7] ^ d[5] ^ d[4] ^ d[3] ^ d[1] ^ c[30] ^ c[28] ^ c[27] ^ c[26] ^ c[24]; assign newcrc[5] = d[7] ^ d[6] ^ d[4] ^ d[3] ^ d[2] ^ d[1] ^ d[0] ^ c[31] ^ c[30] ^ c[29] ^ c[28] ^ c[27] ^ c[25] ^ c[24]; assign newcrc[6] = d[6] ^ d[5] ^ d[3] ^ d[2] ^ d[1] ^ d[0] ^ c[31] ^ c[30] ^ c[29] ^ c[28] ^ c[26] ^ c[25]; assign newcrc[7] = d[7] ^ d[5] ^ d[4] ^ d[2] ^ d[0] ^ c[31] ^ c[29] ^ c[27] ^ c[26] ^ c[24]; assign newcrc[8] = d[7] ^ d[6] ^ d[4] ^ d[3] ^ c[28] ^ c[27] ^ c[25] ^ c[24] ^ c[0]; assign newcrc[9] = d[6] ^ d[5] ^ d[3] ^ d[2] ^ c[29] ^ c[28] ^ c[26] ^ c[25] ^ c[1]; assign newcrc[10] = d[7] ^ d[5] ^ d[4] ^ d[2] ^ c[2] ^ c[29] ^ c[27] ^ c[26] ^ c[24]; assign newcrc[11] = d[7] ^ d[6] ^ d[4] ^ d[3] ^ c[3] ^ c[28] ^ c[27] ^ c[25] ^ c[24]; assign newcrc[12] = d[7] ^ d[6] ^ d[5] ^ d[3] ^ d[2] ^ d[1] ^ c[4] ^ c[30] ^ c[29] ^ c[28] ^ c[26] ^ c[25] ^ c[24]; assign newcrc[13] = d[6] ^ d[5] ^ d[4] ^ d[2] ^ d[1] ^ d[0] ^ c[5] ^ c[31] ^ c[30] ^ c[29] ^ c[27] ^ c[26] ^ c[25]; assign newcrc[14] = d[5] ^ d[4] ^ d[3] ^ d[1] ^ d[0] ^ c[6] ^ c[31] ^ c[30] ^ c[28] ^ c[27] ^ c[26]; assign newcrc[15] = d[4] ^ d[3] ^ d[2] ^ d[0] ^ c[7] ^ c[31] ^ c[29] ^ c[28] ^ c[27]; assign newcrc[16] = d[7] ^ d[3] ^ d[2] ^ c[8] ^ c[29] ^ c[28] ^ c[24]; assign newcrc[17] = d[6] ^ d[2] ^ d[1] ^ c[9] ^ c[30] ^ c[29] ^ c[25]; assign newcrc[18] = d[5] ^ d[1] ^ d[0] ^ c[31] ^ c[30] ^ c[26] ^ c[10]; assign newcrc[19] = d[4] ^ d[0] ^ c[31] ^ c[27] ^ c[11]; assign newcrc[20] = d[3] ^ c[28] ^ c[12]; assign newcrc[21] = d[2] ^ c[29] ^ c[13]; assign newcrc[22] = d[7] ^ c[24] ^ c[14]; assign newcrc[23] = d[7] ^ d[6] ^ d[1] ^ c[30] ^ c[25] ^ c[24] ^ c[15]; assign newcrc[24] = d[6] ^ d[5] ^ d[0] ^ c[31] ^ c[26] ^ c[25] ^ c[16]; assign newcrc[25] = d[5] ^ d[4] ^ c[27] ^ c[26] ^ c[17]; assign newcrc[26] = d[7] ^ d[4] ^ d[3] ^ d[1] ^ c[30] ^ c[28] ^ c[27] ^ c[24] ^ c[18]; assign newcrc[27] = d[6] ^ d[3] ^ d[2] ^ d[0] ^ c[31] ^ c[29] ^ c[28] ^ c[25] ^ c[19]; assign newcrc[28] = d[5] ^ d[2] ^ d[1] ^ c[30] ^ c[29] ^ c[26] ^ c[20]; assign newcrc[29] = d[4] ^ d[1] ^ d[0] ^ c[31] ^ c[30] ^ c[27] ^ c[21]; assign newcrc[30] = d[3] ^ d[0] ^ c[31] ^ c[28] ^ c[22]; assign newcrc[31] = d[2] ^ c[29] ^ c[23]; endmodule module myblkinv2(in,out); input[31:0] in; wire[31:0] out; output[31:0]out; assign out[31]=~in[0]; assign out[30]=~in[1]; assign out[29]=~in[2]; assign out[28]=~in[3]; assign out[27]=~in[4]; assign out[26]=~in[5]; assign out[25]=~in[6]; assign out[24]=~in[7]; assign out[23]=~in[8]; assign out[22]=~in[9]; assign out[21]=~in[10]; assign out[20]=~in[11]; assign out[19]=~in[12]; assign out[18]=~in[13]; assign out[17]=~in[14]; assign out[16]=~in[15]; assign out[15]=~in[16]; assign out[14]=~in[17]; assign out[13]=~in[18]; assign out[12]=~in[19]; assign out[11]=~in[20]; assign out[10]=~in[21]; assign out[9]=~in[22]; assign out[8]=~in[23]; assign out[7]=~in[24]; assign out[6]=~in[25]; assign out[5]=~in[26]; assign out[4]=~in[27]; assign out[3]=~in[28]; assign out[2]=~in[29]; assign out[1]=~in[30]; assign out[0]=~in[31]; endmodule - Altera_Forum
Try:
inverting the input inverting the output(this one is usually obvious) reversing the word order in reversing the word order out All combinations of that. I had a similar situation where a CRC I had was supposed to match that of a "black-box" CRC. What a pain. On top of it all there was a typo in one of the equations so it used the wrong bit. It was a week of my life I'd love to get back. Bottom line is be rigorous in checking every combination. (The final one was flipping the order of 8-bit boundaries, but I think that was unique to my case...)
