17 years agoFaulty State Machine
Hi there, There is a bug in the following state machine that sometimes causes the state transits directly from standby to locked (or some undefined state and stays there) when the enable signa...
17 years agoThank you all for your replies. I will definitely consider to use single-process approach of coding state machines from now on, even just for the sake of reducing the portition of asynchronous design.
For this particular problem, FvM and alt1000 were right on the point. The enable signal was coming from a different clock domain and I forgot to sync it in :o . Now I had fixed it and the problem went away. Lesson learned. :D
