17 years agoFaulty State Machine
Hi there, There is a bug in the following state machine that sometimes causes the state transits directly from standby to locked (or some undefined state and stays there) when the enable signa...
17 years agoAlso, if you have a signal coming into the chip that you are using it in a synchronized state machine you absolutely have to be sure to synchronize it, especially at high speed clock rates and if that signal changes often or has fast edge rates. You can do that using a shift register type of approach or one like this article shows: http://www.edn.com/articles/pdfs/edn/20000106/01d24651.pdf . Altera and Xilinx both have whitepapers on metastability that you might want to read if you are unfamiliar with this
