17 years agoFaulty State Machine
Hi there, There is a bug in the following state machine that sometimes causes the state transits directly from standby to locked (or some undefined state and stays there) when the enable signa...
17 years agoI know many tell you to use two or three processes for fsm but I only trust using one single clocked process. This avoids the clutter of code and combinatorial issues.
Try this change(not tested obviously)
process (n_pur, clk)
begin
if n_pur='0' then
asd_cs <= standby;
lock <= '0';
rate <= "00000";
rate_tmp1 <= "00000";
asd_pass_reg <= 0;
lock_tmp <= '0';
state_tmp <= '0';
rate_tmp <= "00000";
counter_fsm_en <= '0';
asd_pass <= 0;
elsif rising_edge (clk) then
lock <= lock_tmp;
rate <= rate_tmp;
rate_tmp1 <= rate_tmp;
asd_pass_reg <= asd_pass;
case asd_cs is
when standby =>
lock_tmp <= '0';
state_tmp <= '0';
rate_tmp <= rate_tmp1;
asd_pass <= 0;
if enable = '1' then
asd_cs <= detecting;
end if;
when detecting =>
lock_tmp <= '0';
state_tmp <= '1';
counter_fsm_en <= '1';
if s2_rate = last_detected_rate and s2_rate /= "00000" and output='1' then
asd_pass <= asd_pass_reg+1;
else
asd_pass <= 0;
end if;
if enable = '0' then
asd_cs <= standby;
elsif asd_pass >= asd_max_pass-1 then
asd_cs <= locked;
end if;
when locked =>
lock_tmp <= '1';
state_tmp <= '0';
rate_tmp <= s2_rate;
asd_pass <= 0;
asd_cs <= standby;
end if;
when others => null;
end case;
end if;
end process;
