16 years agofaster FP accumulation
Hi, I'm working on a project that requires accumulation. The input comes from a pipeline that outputs node id and value, and the accumulation result must be stored in a block ram. So this invo...
16 years agoYes, I understand that you have arbitrary addresses, I didn't asume this. The suggestion doesn't work in this case and I fear, there is no simple solution at all. Designing a special FP adder with a higher grade of parallelization (and higher resource requirement) may be the only feasible way.
