16 years agofaster FP accumulation
Hi, I'm working on a project that requires accumulation. The input comes from a pipeline that outputs node id and value, and the accumulation result must be stored in a block ram. So this invo...
16 years agoI know what you're saying - but what I worry about is what if data to the same address shows up within 6 cycles. I.e.
Cycle 0 comes in with id 15, data 12.5 cycle 1 comes in with id 20, data 32.5 cycle 2 comes in with id 15,data 13.5 ... The question here is, what should I do if in cycle 4 comes id 15?the first addition for id15 hasn't Finished yet(it finishes at cycle 8) hope this clarifies my question a little bit. Thanks
