17 years agoFalse triggering on dff?
I am using a Cyclone III starter kit with Quartus II v8.1 web edition. I am using library components to make a "one shot" with variable delay times in the msec range. There does not appear to be an...
17 years agoI would change the design to not clock the dff with a combinatorial signal. Register your aeb output and use the registered version to clock your flip flop. If that's not acceptable, you need to implement some sort of glitch-suppression (like maybe a gray encoder).
Jake
