ericmtzr
4 years agoFailure to decrypt IP Core
We received an encrypted IP core from "Praesum Communications" to use on our Arria 10 GX FPGAs. Platform Designer is able to generate HDL and the IP Generation compilation step work, however, when it...
RichardT_altera
4 years agoIf the IP is encrypted in Quartus using IEEE, by right it should be able to compile.
Is the vendor IP currently working with the Intel on resolving the issue?
Do you still need my help? If so, I need a way to duplicate the issue from my end. e.g. a dummy IP.
