ericmtzr
4 years agoFailure to decrypt IP Core
We received an encrypted IP core from "Praesum Communications" to use on our Arria 10 GX FPGAs. Platform Designer is able to generate HDL and the IP Generation compilation step work, however, when it...
RichardT_altera
4 years agoHave you consult the vendor IP beforehand? Since they are the one providing the IP so they should know if one or more of their end customer having similar issue. Also, can check whether the IP is encrypted using Quartus or third party tool?
Is the IP able to compile without encryption in first place?
Could you provide me the IP so I can investigate?
ericmtzr
4 years agoHi,
The IP compiles and regenerates fine in Platform Designer.
The IP vendor is pursuing it with Intel. They said that it was encrypted using Quartus.
I think the client is working with Intel directly.
