16 years agoFailed to start the software
Hi all,
After install the cyclone III, I get the message below: Could not establish JTAG connection between the board and control panel application. Please ensure the board is configured with the correct programming file and download cable is connected properly to the board. appreciate if any help can be provided Thanks Best regards charley14 Replies
Does anyone know if this board will conflict with any other installed FTDI driver?
I'm running into the same 57% done hang up issue using Altera SBT 10.1sp1. Restarting the IDE didn't make a difference. :confused:
Co-worker of mine told me to go back to the legacy tools. Did any of you come up with a workable solution? - Altera_Forum
Dear folks,
I am having this same problem "could not establish JTAG connection between the board and control panel application. Please ensure the board is configured with the correct programming file and download cable is connected properly to the board.". I have went through all the replies to this problem and couldn't find any satisfying solution. I am using Cyclone II, EP3C25F324 starter kit v12.0.0, along with Quartus II 13.0 programmer. I used 'cycloneIII_3c25_start_niosII_standard.sof' for fpga configuration using the Quartus II 13.0 programmer and it shows 100% success in the JTAG mode. One of the solutions stated is above is to use version 9 for Quartus II , NIOS II and related softwares. But that don't seem a convincing approach for me. I am a tyro to fpga programming, please help. - Altera_Forum
--- Quote Start --- Did you ensure that the board is configured to the correct programming file? Had you install the driver from our website? --- Quote End --- I face the same problem in New Cyclone III EP3C25F324 starter development board, when I try to start Board Test System I get a message "could not establish jtag connection between the board and control panel" I am using cyclone 3 starter kit 12.0.0 and quartus web edition 12.0sp2, with Altera usb blaster properly installed. As I am using it first time so, also tell me how to configure the board with correct programming file. Any suggestions?
