failed in creating agilex-f p-tile-pcie-avmm (RP X4) design example
- 6 years ago
Sorry, I overlook the dev kit setting. After putting the Agilex dev kit and generate the ED, the design files look bigger so I can't directly attach to here.
Here is the step to get the file:
Install Filezilla that can download from here:
https://filezilla-project.org/download.php?type=client
After installing, launch the tool and login as below:
Host: secureftp.intel.com
Username: tmp01481
Password: W@ng1234
Port 21.
You can see the zip file is located at the right of the window. Name = wang_ag.zip.
Hi Sir,
I am attached the generated ED that based on your required setting.
Downloaded the zip file, thank you very much for the help. I am learning it now.
I saw that in the .ip file the the "current development kit" option is set to "none" instead of the agilex board. Any reason for doing it? For my understanding, the example design should target to a board in order to correctly assign the design IO pads locations. What should I know about this?
Xiao
