failed in creating agilex-f p-tile-pcie-avmm (RP X4) design example
- 6 years ago
Sorry, I overlook the dev kit setting. After putting the Agilex dev kit and generate the ED, the design files look bigger so I can't directly attach to here.
Here is the step to get the file:
Install Filezilla that can download from here:
https://filezilla-project.org/download.php?type=client
After installing, launch the tool and login as below:
Host: secureftp.intel.com
Username: tmp01481
Password: W@ng1234
Port 21.
You can see the zip file is located at the right of the window. Name = wang_ag.zip.
By the way, are you able to generate the standalone IP? Also do you try to generate other IP's ED?
I am new in using the Quartus tool and the first practice is to generate the PCIe RP IP. So I have not do any other IP-DE yet.
regards,
Xiao
- seanw_skhms6 years ago
I think the example design generation failure is caused by a bug in adding in the module of clock_crossing_bridge. The error message, at line#40 shown in "received_error_2.log" attached previously, shows,
Error: add_fileset_file: No such file C:/Users/PC_LAB_FPGA1/AppData/Local/Temp/alt8499_1907179446840489927.dir/0001_intel_pcie_ptile_avmm_0_gen/ip/pcie_ed/pcie_ed_clock_crossing_bridge/altera_avalon_mm_clock_crossing_bridge_1920/synth/pcie_ed_clock_crossing_bridge_altera_avalon_mm_clock_crossing_bridge_1920_fdcxukq.v/pcie_ed_clock_crossing_bridge_altera_avalon_mm_clock_crossing_bridge_1920_fdcxukq.v
The file name of "pcie_ed_clock_crossing_bridge_altera_avalon_mm_clock_crossing_bridge_1920_fdcxukq.v" is inserted two times in the file searching path.
(But the message at line#38-39 shows that the other two rtl files, "*dc_fifo_1920_qcx4w5q.*", in the same folder were fetched correctly.)
regards,
Xiao
