failed in creating agilex-f p-tile-pcie-avmm (RP X4) design example
- 6 years ago
Sorry, I overlook the dev kit setting. After putting the Agilex dev kit and generate the ED, the design files look bigger so I can't directly attach to here.
Here is the step to get the file:
Install Filezilla that can download from here:
https://filezilla-project.org/download.php?type=client
After installing, launch the tool and login as below:
Host: secureftp.intel.com
Username: tmp01481
Password: W@ng1234
Port 21.
You can see the zip file is located at the right of the window. Name = wang_ag.zip.
Hello Sir,
I open your latest attached. ip file and generate the example design from there. The generation is successful.
I believe the Agilex Example design (ED) is create based on the faster speed grade for now, so no matter what device that you set in your project, the example design will generate based on the device AGFB014R24A2E2VR0.
Just want to let you know that the support for Ptile PCIe IP in Agilex is still in prelim stage, thus it might not cover across all speed grade.
At this moment, do you want me to send you my generated example design so that you can use it directly without generation?
Also, are you mentioned that the “Current development kit” in your GUI is empty? From my side, I can see “none”, “S10 DX” and “Agilex”.
In the "IP Parameter Editor Pro" window, when I clicking the "Generate HDL ..." control button located at bottom-right corner, the generation is always successful no matter of the "Enable PHY Reconfiguration" selection. But when clicking the "Generate Example Design ..." control, the generation are always failed no matter of the "Enable PHY Reconfiguration", or the "Current development kit" or the "Design Environment" (standalone/system) selections.
The Agilex F-series development kit, intel PN# DK-DEV-AGF014E3ES we purchased, has the device of AGFB014R242E3VR0 installed. The current released version of Quartus tool has to be able to support it. I saw the log message shows that the generation uses AGFB014R242E3VR0 sometimes, but not always. I saw the both of AGFB014R242E3VR0 and AGFB014R242E2VR0 devices are listed in the *.ip file, which looks not right for me.
I am able to see the "none, stratix, agilex" options in the "Current development kit" control, and I set to use the agilex developemnt kit. I saw your log message, "ptile_generated.txt", shows that the generation is targeting to Stratix 10 development kit, but the device is AGFB014R242E2VR0, which looks so wrong for me. I made a test by selecting the Stratix 10 development kit, the log message shows that the tool changed the device to 1SD280PT2F55E2VGS1.
If I open the "Device Family" window, the device setting shows the right values of "Agilex" and "AGFB014R242E3VR0". but why the "Stratix 10" development kit still shows up in the generating option?
The "Current development kit" has the "Agilex F-Series" development kit option, but I do not see how and where this board is set in the tool. When following the document ug-20268, section 5.3 to run the "file->new project wizard", in the "family, device & board" setting page, the "board" tab is empty. I believe the Agilex-F development board should be shown here, but I could not find out how to add it in.
Could you please help to generate a RP IP with example design for me by using the following settings,
family : Agilex
device : AGFB014R242E3VR0
development kit : Agilex F-Series
IP : intel-pcie-ptile-avmm
Design environment : System
Hard-IP mode : Gen4x4, interface - 128 bit
Port-Mode : Root Port
PLD Clock Frequency : 350 MHz
Example Design Files are for Synthesis only in verilog format targeting to Agilex-F development kit.
Then let me know how to download the whole design folder.
Xiao
