nikhl's avatar
nikhl
3 years ago
Failed Co simulation of a Example HLS design
Hi ,
I am have installed the intel Quartus prime 22.2 development suite in my system and tried to compile and test the HLS counter example design but it fails in the Co-simulation.
i++ counter.cpp  -v   -march=Arria10 -o test-fpga
Target FPGA part name:   10AX115U1F45I1SG
Target FPGA family name: Arria10
Target FPGA speed grade: -1
Analyzing counter.cpp for testbench generation
Creating x86-64 testbench
Analyzing counter.cpp for hardware generation
Verifying version information in the included files.
Expecting version 22.2.0.46.1 for all included files.
Included files passed version check. Checked:  none.
Optimizing component(s) and generating Verilog files
Generating cosimulation support
Generating simulation files for components: count
HLS simulation directory: /home/lsai_nikhil/intelFPGA_pro/22.2/hls/examples/counter/test-fpga.prj/verification.
HLS Elaborate verification testbench FAILED.
See /home/lsai_nikhil/intelFPGA_pro/22.2/hls/examples/counter/test-fpga.prj/debug.log for details.
Error: Cosim testbench elaboration failed.
Makefile:53: recipe for target 't
I have checked the debug .log ,
Debug log output:
/home/lsai_nikhil/intelFPGA_pro/22.2/hls/host/linux64/lib/libhls_cosim_msim32
# -dpioutoftheblue 1 -sv_lib /home/lsai_nikhil/intelFPGA_pro/22.2/hls/host/linux64/lib/libhls_cosim_msim32
# [exec] elab
# vsim -dpioutoftheblue 1 -sv_lib /home/lsai_nikhil/intelFPGA_pro/22.2/hls/host/linux64/lib/libhls_cosim_msim32 -L work -L work_lib -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_v
er -L twentynm_ver -L twentynm_hssi_ver -L twentynm_hip_ver -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L twentynm -L twentynm_hssi -L twentynm_hip -L hls_sim_main_dpi_controller_10 -L main_dp
i_controller -L hls_sim_component_dpi_controller_10 -L dpic_count -L avalon_conduit_fanout_10 -L count_cfan -L count_en_cfan -L hls_sim_clock_reset_10 -L clock_reset -L avalon_concatenate_singlebit_condui
ts_10 -L cat_done -L count_internal_10 -L count -L cat_cwfsw -L avalon_split_multibit_conduit_10 -L sp_cstart -L altera_irq_mapper_2000 -L tb tb.tb
# Start time: 10:26:00 on Oct 19,2022
# ** Fatal: ** Fatal: (vsim-3827) Could not compile 'export_tramp.so': cmd = '/home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/gcc   -shared -fPIC -m32 -B/usr/lib32  -g  -I. -I"/home/lsai_nikhil/intelFPGA_pro
/19.3/modelsim_ase/include" -I"/home/lsai_nikhil/intelFPGA_pro/19.3/modelsim_ase/../oem/include" -o "/tmp/lsai_nikhil@server1_dpi_11933/linuxpe_gcc-9.3.0/export_tramp.so" "/tmp/lsai_nikhil@server1_dpi_119
33/linuxpe_gcc-9.3.0/export_tramp.S"'
# (vsim-50) A call to system(/home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/gcc   -shared -fPIC -m32 -B/usr/lib32  -g  -I. -I"/home/lsai_nikhil/intelFPGA_pro/19.3/modelsim_ase/include" -I"/home/lsai_nikhil/
intelFPGA_pro/19.3/modelsim_ase/../oem/include" -o "/tmp/lsai_nikhil@server1_dpi_11933/linuxpe_gcc-9.3.0/export_tramp.so" "/tmp/lsai_nikhil@server1_dpi_11933/linuxpe_gcc-9.3.0/export_tramp.S" >'/tmp/quest
atmp.j5QHxs' 2>&1) returned error code '1'.
# The logfile contains the following messages:
# /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../x86_64-pc-linux-gnu/bin/ld: skipping incompatible /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x8
6_64-pc-linux-gnu/9.3.0/libgcc.a when searching for -lgcc
# /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../x86_64-pc-linux-gnu/bin/ld: cannot find -lgcc
# /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../x86_64-pc-linux-gnu/bin/ld: cannot find -lgcc_s
# collect2: error: ld returned 1 exit status
# No such file or directory. (errno = ENOENT)
# FATAL ERROR while loading design
# ** Error: Error loading design
# Executing ONERROR command at macro ./msim_compile.tcl line 15
# End time: 10:26:15 on Oct 19,2022, Elapsed time: 0:00:15
Can anyone help me to resolve the issue?
@intel
  • hareesh's avatar
    hareesh
    may i know your pc supporting 32 bit or 64 bit os?
  • nikhl's avatar
    nikhl
    Hi
    My System is x86-64 bit , it supports 64 bit OS .
  • hareesh's avatar
    hareesh
    i am also facing problem with my compiler pls give me some time i will give the solution.
    Thank you,
  • hareesh's avatar
    hareesh
    in my machine it's working fine. no problem. i am trying to duplicate your issue, so i need some information about your os
    1. which os are using
    2. quartus version
    and once check HLS compatibility also
    The Intel HLS Compiler Pro Edition Version 22.3 is compatible with the following Intel
    Quartus Prime software:
    • Intel Quartus Prime Pro Edition Version 22.3
    • Intel Quartus Prime Pro Edition Version 22.2
    • Intel Quartus Prime Pro Edition Version 22.1
    • Intel Quartus Prime Pro Edition Version 17.1.1
    • Intel Quartus Prime Standard Edition Version 21.1
    The Intel HLS Compiler supports only Cyclone® V devices in Intel Quartus Prime
    Standard Edition.
    Intel Quartus Prime Lite Edition Version 21.1
    The Intel HLS Compiler supports only Cyclone V devices in Intel Quartus Prime Lite
    Edition .
  • nikhl's avatar
    nikhl
    Hi @hareesh ,
    I am using Ubuntu 18.04 , Kernel: 4.15.0-162-generic.
    Also I am using the Quartus prime pro 22.2 version.
  • hareesh's avatar
    hareesh
    follow the bellow document. execute in that way. and attached counter example design file try with that.
    if you are facing same problem after that please download HLS compiler and install it and try same procedure.
  • hareesh's avatar
    hareesh
    did you tried what i shared steps?
    please update the status of your issue
  • nikhl's avatar
    nikhl
    I tried the above steps, still it shows " HLS Elaborate verification testbench FAILED. "
  • hareesh's avatar
    hareesh
    As we discoursed in call please update your simulators and same steps.
  • hareesh's avatar
    hareesh
    Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
