Seven_12345's avatar
Seven_12345
6 years ago
FA request of Intel FBGA LJ40GAE0T00 failure at Quanta SMT BFT test
Quanta (Shanghai Chian) found 1 PCS intel FBGA(IC CTRL(1517P)10AXF40GAE(FBGA)EMSMSF) fail, at SMT function test found the MB which built this FBGA happened Factory test scripts internal error, replaced the FBGA re-test MB Pass, SMT PE had done the cross validation found the failure following the FBGA, so we need Intel support the FA request of this fail FBGA, please help check and give the feedback soon. Thanks!
  • Zawani_M_Intel's avatar
    Zawani_M_Intel
    HI Seven_12345,
    Can you share with me the pins you used and suspected failed pin?
    Wani
    Please consider of any confidential info you might shared publicly. If you need private message, please do let us know.
    • Seven_12345's avatar
      Seven_12345
      Hi Wani, I asked our SMT PE help check and provide the used pins and suspected fail pin at our SMT function test, need more detail failure information, please send a mail to me freely. My mail box: [email protected] Thanks!
