F-Tile PCIe Hard IP Linux Driver
F-Tile PCIe Hard IP Page below says there is a Linux driver for the IP. How Can I access the driver files / project ? Is there any SW example using this driver? Please specify the direct link.
Kind Regards
Emrah ENER
- Wincent_Altera
Hi
Glad that it is able to help you
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
- Wincent_Altera
I wish to follow up with you.
Am I answering your question ?
Wincent_Intel
- emrahener
Thanks Wincent,
That answers all my current questions.
Kind Regards,
Emrah ENER
- Wincent_Altera
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
Else I would like to have your permission to close this forum ticket
Wincent_Intel
- emrahener
Hi Wincent,
When will 2023.2 be available ? My question was on driver availability. From your reply I understand that example HW design generation will be possible starting from 2023.2. Will HPS drivers for root port also be available at the same time ?
- Wincent_Altera
Expected will release before the end of Quarter 2.
the date still TBC "to be confirm".
When it releases, feel free to resubmit a new ticket.
The support specialist shall help you with that.Regards,
Wincent_Intel
- Wincent_Altera
I wish to follow up with you about this IPS case.
Do you have any further question on this ?
Wincent_Intel
- Wincent_Altera
Currently the rootport mode design example for Agilex is not available.
Expected will release at Quartus v23.2 (TBC)
Hope that answered your question.
Wincent_Intel
- Wincent_Altera
For Arria 10 DMA memory read/write, you can refer to user guide below
Under section 5.1.1 Read DMA Avalon-MM Master Port
and 5.1.2 Write DMA Avalon-MM Master Port
Let me know if this is helpful.
Wincent_Intel
- Wincent_Altera
Please ignore this reply, let me have sometime to find out the drivers/ libraries/example sw on HPS side
Wincent_Intel
- Wincent_Altera
You can refer link below for Linux Kernal driver installation.
Wincent_Intel
- emrahener
Hi Vincent,
We will be using this IP as a 4x4 Gen4 Root Port and I am asking for drivers/ libraries/example sw we can use on HPS side. Not for device mode but for root port mode.
-Will the those drivers Memory mapped configuration port ?
-For Enumerating devices and assigning physical addresses is there any SW involvement or is it purely done by Fabric side ?
Kind Regards,
Emrah ENER
- Wincent_Altera
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Wincent_intel
