emrahener
3 years agoF-Tile Interlaken Intel® FPGA IP Example Design External Loopback HW Test
Hi, I am using F tile Interlaken IP on AGIB027R31BE2VAA device using Quartus 23.1. I am loading Example design generated for 12x12.5 Gbps NRZ Configuration to my custom HW and using the system cons...
ZiYing_Intel
3 years agoHi,
Since the issue has been raised in the IPS, then let us just discuss the issue in the IPS. Firstly, you need to ensure you loading the .sof file successfully and I will be need some time to do the debugging of the problem from my side.
Zi Ying
