11 years agoEye pattern using TCL script
Is there any way to generate an eye pattern using TCL sript. I'm a newbie here so i have no idea regarding how to do that.
11 years ago --- Quote Start --- Is there any way to generate an eye pattern using TCL sript. I'm a newbie here so i have no idea regarding how to do that. --- Quote End --- Yes, you can, however, since you are a newbie, that is not where you should start. You first need to determine whether you are using an FPGA that supports eye-pattern measurement (only the newer Stratix V and Arria V GZ parts support it). Then you need to use the Transceiver Toolkit to get familiar with the eye pattern features. Only then should you look into writing your own eye pattern Tcl code. Read the Transceiver Toolkit documents I have written on this page: https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html Cheers, Dave Cheers, Dave
