9 years agoExtremelly confused in Cyclone V Transceivers reconfiguration
Hello dear friends. I have a Cyclone V 5CSXFC6D6F31C8 chip. On PCB board, all 9 transceivers are connected to periphery and 1 reference clock (REFCLK1L) are connected to reference clock source ...
8 years agoSo i return to this problem after some time.
Now i'm stay off in this point: The project consist of these modules: - Separate FPLL with it own PLL Reconfigurator IP. - Transceiver in external PLL mode (i use 2 TX PLL's - TXPLL0=622.08 and TXPLL1=2488.32, bonding xN used). - Base speed of transceiver is 622.08 (and 322.04 for FPLL respectively). - Transceiver reconfiguration IP (number of channels same as number of channels in transceiver, MIF reconfiguration enabled). What results i have: For channels count from 1 to 6 compilation are successful. For channels count from 7 to 8 compilation fails with errors:
Info (170193): Fitter routing operations beginning
Error (170084): Can't route signal "xcvr:inst3|altera_xcvr_native_av:xcvr_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.int_wire_clk" to atom "xcvr:inst3|altera_xcvr_native_av:xcvr_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.tx_cgb"
Info (170194): Fitter routing operations ending: elapsed time is 00:00:01
Can anybody help me with it?
