External watchdog connect to nConfig pin or nReset pin of FPGA?
- 6 years ago
Hi Jasmine,
It will depend on your design an how critical the issue is. If you would like to have a faster reset and have the FPGA function then I would recommend to use the nReset pin.
If you are using nConfig pin it will reconfigure the FPGA to golden image and you will need to wait for it to reconfigure to application image before your design start to function.
Hi Jasmine,
- Mingyuexin6 years ago
Thank you very much for the answer, I got it.
With best wishes
Jasmine
