16 years agoExternal trigger so easy?
I just want to use the signal generator to trigger one IO pin of FPGA externally. On FPGA , this trigger sigal will be captured on the rising edge. But, when I just connect the IO pin on FPGA to t...
16 years ago --- Quote Start --- I use oscillograph to measure max voltage. What's wrong? --- Quote End --- Set oscillograph in waiting mode. Use probe with low input capacitance. If you have a cat, play with them. After, touch a probe.
