16 years agoExternal trigger so easy?
I just want to use the signal generator to trigger one IO pin of FPGA externally. On FPGA , this trigger sigal will be captured on the rising edge. But, when I just connect the IO pin on FPGA to t...
16 years agoThanks ,Ton and BOND! Good advice for me! Really appreciatate that!
So, why just 500 mV can do the things that 3 V or some can do? IS it because electromagnetic interface, for that float pins can be affected larger interface than others?
