16 years agoexposed pad in EQFP package
Hi, I have a problem with the exposed pad in the EQFP 144pin package. What is the correct way the connect the exposed pad to the PCB ? I cannot simple solder it because it has height a...
16 years agoThanks FvM.
The height Issue : Because the exposed pad, when placing the FPGA in place, has height from the PCB - you need to put a lot amount of solder in order to connect the pad in the PCB and the exposed pad with solder. FvM, Is this your preffered techniqe or you recomend to do it in an other way ? thanks, Amir
