16 years agoExit code = 11... Device verify failure
Hi, I use Jam STAPL Player Version 2.5 to implement CPLD upgrade. But the program return "Exit code = 11... Device verify failure" 1. My system is ARM cpu on Embedded Linux. 2. I only ch...
16 years agoHi Panda,
thanks for your answer. I thought i has adjust this parameter exactly, but i measure it again and found that the timing wasn't excat enough, because the function do_wait_microseconds is called with values over 500.000! Now it works fine! Best regards Thomas
