amaltaha
4 years agoException in running vector-add on FPGA device on arria10 devcloud
I am trying to run vector-add of fpga_compile example on Intel oneAPI devcloud on hardware FPGA by ./fpga_compile.fpga
I have connected through ssh on MobaXterm and I have specified the ...
- 4 years ago
using the command
dpcpp -fintelfpga -Xshardware <source_file>.cppSolved the problem, make fpga didn't work on any node. probably the problem is in my side.
Thank you!
aikeu
4 years agoHi amaltaha,
I have tried to run the vector add example:
It was ok from my side where I was able to run the whole program following the document without errors.
Sometimes the nodes may encounter issues and is better to retry again or on other nodes.
Aik Eu
