MZhao20
6 years agoExample of Transceiver error reporting
Customer JESD204B receives and sends the transceiver in the same pair. Because the sampling rate is different, the transceiver is modeled separately. RX channel tx_serial_j204[0] and TX channel rx_s...
CheepinC_altera
6 years agoHi,
As I understand it, you have some inquiries related to merging simple JESD TX and RX into the same XCVR channel. As I browse through the JESD204B user guide, I am unable to find specific information on the TCL command to perform the merging. Would you mind to point me to the specific section on this in user guide or any web reference which mention about JESD simple merging so that I could further probe from there?
Thank you very much.
