12 years agoEVB for high-speed LVDS-to-LVCMOS conversion?
Does Altera have an EVB (or a set of EVBs) I can use for high-speed multi-input LVDS-to-LVCMOS conversion? I think what I want is a converter that is an LVDS bus on the input side to parallel LVCMOS on the output side.
I want to capture and record to disk the bit streams that constitute the LCD display interface logic for embedded LCD displays. Most often, these are LVDS on the physical layer. I want to convert the LVDS bit streams to LVCMOS bit streams and then record the synchronized streams to disk. I want to be able to thus capture and record multiple LVDS inputs (say, 4 channels or 8 channels), deserialize the data, keep things synchronized, convert to parallel LVCMOS streams, and record these converted (LVCMOS) bit streams to disk. I want to be able to handle 400 Mbit/s (200Mhz) on the LVDS input bus. I want a reliable and stable conversion and capture. The capture sessions will average up to 10 minutes per session. I also have the problem of interfacing to the DUT. I want to capture the LVDS bit streams without loading the DUT. I want to be able to keep the LCD on the DUT in place and daisy-chain off the LCD cable to provide input to the converter. Is there an EVB or set of EVBs that will suit my needs? Is there associated software I can use (or enhance/modify) to record the captured and converted bit streams to disk on a Windows PC?No RepliesBe the first to reply
