Ethernet Phy Fails to Link Between Marvell 88E111 PHY and Downstream port
Hi Per Moberg,
According to the 88EE111 Datasheet, I found that in HWCFG_MODE[3:0] ’0000’, ’0100’, ’1000’, and ’1100’, RXD[3:2] can be used to indicate the copper link status. In this mode the LED_LINK10, LED_LINK100, and LED_LINK1000 pins cannot be used to indicate copper link status because the LED_LINK10, LED_LINK100, and LED_LINK1000 toggle during configuration.The RXD[3:2] pins must strictly indicate copper link status and not mirror the LED output. The link status will be real time status.
The definition of RXD[2] is 1 = Copper link down, 0 = Copper link up. The definition of RXD[3] is 0 = Copper link down, 1 = Copper link up.
In my opinion, you may try change the HWCFG_MODE[3:0] to the mode that can be used to indicate the copper link status and change the RXD[3:2] pins.
If above suggestion still not work, please do try to debug the problems according to the solution provided in below:
- Please do ensure the cable is connected correctly.
- Please do check whether you are using DHIP or static IP in your pc. If you are using DHCP, please try use a Static IP.
- Please try adding a 100 clock cycle delay till drive the ethernet PHY reset line high when the board lights up.
Zi Ying
