12 years agoEthernet not work with Linux on HPS
hello, I copied the files from rocketboards to the sd card and configure all of the switchs and jumpers. My linux boot but I never succeeded to connect the board on the network to test the web appl...
12 years agoFirst console Eth-error is before login ask!
In my kit output to RS, its there:libphy: stmmac: probed
eth0: PHY ID 00221611 at 4 IRQ 0 (stmmac-0:04) active
Initializing USB Mass Storage driver... I don't replace original contents of SD-card, may send my files to e-mail, only not fast. These files is all visible if insert SD-card in PC through adapter, included with kit: soc_system.rbf 6843 K 05.11.13 01:05
socfpga.dtb 18049 05.11.13 01:05
u-boot.scr 200 05.11.13 01:05
zImage 3128 K 05.11.13 01:05 May be incompatible version of device tree on rocketboards, need be ask there. Or if Eth-interface disabled through jumpers ? Or power/ground pin isolated ? Press to Eth-Phy, run test soft from Altera... On rocket available previous versions of Linux boot image ? There permanently changes its project... Lanix, please, big console output surround with brackets: "[ code ]" and "[ /code ]" (withoot blanc spaces, its for nonwork inserting)! Or: analogical with "quote. Or may include this as separate file.
