12 years agoEthernet interface based on ARM HPS
Hi everyone! I'm considering possibilities of ethernet interface realization on HPS. What I need is data speed up to 20 Mbits/s and IP routing function. Where to start from? I'm thinking about usi...
12 years agoYou should be fine using the Ethernet for both debug and your own application. As long as you don't try to use the same port number the debugger is using, Linux will take care of routing the packets to the correct place for you. Just connect your debug PC, the HPS Ethernet, and what it is communicating with to an Ethernet switch (not a router).
