AEsqu
Contributor
4 years agoEthernet blaster cyclone V
I use a cyclone V using the USB blaster without probem.
Then I wanted to use the ETHERNET Blaster , it is ok on the network and I can access it, as well as the server web page.
I can add...
Ash_R_Altera
4 years agoCan you check board connection to the Ethernet Blaster. If you have a verified working one, you could try on the board and see if the behavior is same or not.
If same issue persists, then it could be a board connection issue.
- AEsqu4 years ago
Contributor
I won't use the old ethernet blaster 1, I'll stick to the version 2 which is working fine for a week now.
IP address has been re-assigned to the new MAC address so I cannot test the old one without assigning a new IP address to it.
