Ethernet blaster cyclone V
The LED is purple, means the firmware is upgrading. To correctly upgrade the firmware, follow steps mentioned in section 2 -> Upgrading the Firmware of the user guide.
Upgrading properly could resolve your issue.
- AEsqu4 years ago
Contributor
We bought a Ethernet Blaster II and it was failing to do the DHCP IP addressing on 1 Gbps network but got it working by setting the ethernet switch to 100 Mbps.
It is working, I can use it for ILA.
Is there any firmware upgrade for the Ethernet Blaster II ? The link on the Ethernet Blaster II webserver page points to altera not exisitng webpage.
After a first ILA acquisition, the Ethernet blaster connection is lost under windows 10, but it stays connected under linux, good enough.
Edit: also looses connection after some ILA grabs under Linux...
Alex.
