11 years agoEstimate total computation time in FPGA
Hi, I am using MAX 10 FPGA to implement a controller for my power supply. The VHDL code for the controller is as follows. In this code the input 'I' is a pulse which helps to sample input Iref at ...
11 years agoYou get a negative slack report when you don't have a Synopsys Design Constraints File(.sdc file) that describes the timing requirements. Quartus II then assumes a clock of 1 GHz (1 ns period) which obviously is never met.
