tedh4ddv
3 years agoErrors when implementing a SPI to configuration serial flash bridge
Using Quartus Prime v20.1 Std, for a Cyclone 10 LP design.
The basic project compiles and functions. The problem arises when adding an IP block to bridge an existing SPI interface to the configura...
- 3 years ago
The issue has been resolved here. The design now compiles. It was the default I/O standard setting in Assignments > Device > Device and Pin Options > Voltage. Never had to edit that in the past. Thanks.
NurAiman_M_Intel
3 years agoHi,
Can you provide us your design in .qar? So we can try to recompile from our end.
Thank you.
Aiman
