17 years agoErrors reading M9K dual port in Cyclone III
Hi, We are using four Megawizard generated dual ports in a 3C40F484C8. There are 128 locations, 24 bits wide, asynchronous write and read clocks. A common write_data and write_address bus goes to ...
17 years agoHi,
The memory is instantiated like this -----RAM 1--------------------------------------------------------------------- tx_mezz_ram_1 : tx_mezz_ram port map( wrclock => mezz_rx_clk_pll_out, wraddress => write_addr, data => write_data, wren => wren, rdclock => transmit_clock, rdaddress => read_addr, q => read_data0 ); The Megawizard vhd file is attached, Regards
