paul26
3 years agoError(20783): Open Drain option is set to 'ON' for pin I2C_AUDIO_SDA~pad, but setting is not support
I tried to do a pass through logic for I2C . i have master and slave out side fpga and i need to connect that through fpga. SDA, SCL both are inout pins. So i added a tri state logic for this o...
Farabi_Altera
3 years agoHello,
this is duplicated case with case #05810019.
I will close this one and continue support using case #05810019.
regards,
Farabi
- paul263 years ago
Hi Farabi,
Could not find the solution in the duplicate also
Paul
