16 years ago
Error while traing to
I synthesized my design in Quartus II , "EDA Netlist Writer" and I keep getting the following message:
"Warning: Can't generate output files. Specify command-line options to generate output files, or update EDA tool settings using GUI or Tcl script".
The problem is that the Bank 1 GCLK, in MAX2, EPM2210F256I5 (meant to be enable for clock) in not going up to 3.3V ('1').
what should I do, can anybody help?
Idan
    The problem I also met before, However, I think It did no issues to my design . So I want to ask wether the warning has no influence in arbirary sitution or not .
    --- Quote Start ---
    Idan
    --- Quote End ---
    I think the warning is not related to your problem. The warning occurs, because the default setting of Quartus switched on the so-called EDA Netlist writer. The writer is used
    for generation of a netlist of your design for third party EDA tools like simulation tools.
    Kind regards
    GPK
