16 years agoError while traing to
Hello, I synthesized my design in Quartus II , "EDA Netlist Writer" and I keep getting the following message: "Warning: Can't generate output files. Specify command-line options to genera...
16 years ago --- Quote Start --- Hello, I synthesized my design in Quartus II , "EDA Netlist Writer" and I keep getting the following message: "Warning: Can't generate output files. Specify command-line options to generate output files, or update EDA tool settings using GUI or Tcl script". The problem is that the Bank 1 GCLK, in MAX2, EPM2210F256I5 (meant to be enable for clock) in not going up to 3.3V ('1'). what should I do, can anybody help? Regards, Idan --- Quote End --- Hi, I think the warning is not related to your problem. The warning occurs, because the default setting of Quartus switched on the so-called EDA Netlist writer. The writer is used for generation of a netlist of your design for third party EDA tools like simulation tools. Kind regards GPK
