14 years agoError when uploading the code to the FPGA DE2-70
Hi all, I have followed the example you may find in tut_sopc_introduction_verilog.pdf Everything goes fine to the point where I need to upload the program... Then I get the following ...
14 years agoHi,
Yes i have created an other sdc file "filref.sdc", in which were defined the clocks, i don't use any pll. You find also the Fils "DE2-70-assignemets.csv" and "lights.v". Thank you for your help
