14 years agoError when uploading the code to the FPGA DE2-70
Hi all, I have followed the example you may find in tut_sopc_introduction_verilog.pdf Everything goes fine to the point where I need to upload the program... Then I get the following ...
14 years agoThis is only the sdc file generated with the CPU. I think it is automatically added in the project with the .qip file.
You need to create another .sdc file that defines your clocks. Are you using any pll?
