14 years agoError when uploading the code to the FPGA DE2-70
Hi all, I have followed the example you may find in tut_sopc_introduction_verilog.pdf Everything goes fine to the point where I need to upload the program... Then I get the following ...
14 years agoWhen you see the opencore evaluation window, it is very important not to close it. If you do then the CPU will stop working.
Do you have a .sdc file with the timing constraints? The bare minimum would be one with a line that defines your clock input, although if you are using 50MHz without a pll you shouldn't run into too much timing problems yet.
